lymtics
#1 Posted : Monday, October 29, 2007 2:14:31 PM(UTC)
lymtics
Washer was draining and not spinning or spinning and not draining could shut off and turn timer until machine would complete cycle
Now neither spinning or draining
#2 Posted : Monday, October 29, 2007 2:48:37 PM(UTC)
Most likely the problem with your washer is a bad timer. I'm not able to give you more accurate advise due to incorrect model number.
front load drain/spin problem (Washer Repair)
by tammyclif 7/23/2009 3:59:57 PM(UTC)
