rthompson
#1 Posted : Monday, January 19, 2009 6:30:23 PM(UTC)
rthompson
I am replacing the timer on a Kitchenaid gas dryer. The timer is model M460-G. I have the wiring diagram, but there is an existing white wire with blue stripe that is not shown on the diagram, and there are some unlabeled connectors on the timer. Where does this wire go? I have photos that show the timer wiring and diagram.
rthompson attached the following image(s):
#2 Posted : Wednesday, January 21, 2009 12:14:50 PM(UTC)
Design for this timer has not been changed what means there is no difference between the terminals on both, old and new timers. Just remove one wire at a time from the old timer and plug it into the same terminal on the new one.
