2 Pages12>
Strawman
#1 Posted : Monday, January 19, 2009 4:25:41 PM(UTC)
Strawman
Model fef369cgtc, the door latch is in the locked position, the oven door is open, the door cannot close. The "lock" light is flashing. None of the oven functions are operable, "dr" is displayed. My wife thinks she pressed the "quick bake" switch when this happened. What to do? Thanks.
#2 Posted : Tuesday, January 20, 2009 1:48:55 PM(UTC)
Push and hold the oven light switch(on the door frame). Press the Cancel button on the control panel and look if the door lock will move to open.
Here are the break down diagrams for the Frigidaire range Model FEF369CGTC
Strawman
#3 Posted : Wednesday, January 21, 2009 3:55:27 PM(UTC)
Strawman
That worked beautifully, thanks.
#4 Posted : Wednesday, January 21, 2009 4:52:15 PM(UTC)
You are welcome. I'm glad it was that simple.
elvicare3560
#5 Posted : Saturday, December 12, 2015 9:03:25 AM(UTC)
elvicare3560
Thank-you very much, I don't think I did any damage trying to make it shut before I came upon your great explanation, I really appreciate it, as it closed smoothly and I even got to sweep behind it!!!!!
Guest
#6 Posted : Saturday, May 29, 2021 11:43:47 AM(UTC)
Guest
Rank: Guest
Groups:
United States
Great advice
Guest
#7 Posted : Monday, November 1, 2021 1:37:36 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Just tried the door switch and cancel button , it worked! Thanks so much.
IGURED I out LOCK THANK BEST WISHES TO YOU AND YOUR FAMILY💯🙏👍
#8 Posted : Friday, July 7, 2023 4:54:31 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Guest
#9 Posted : Friday, July 7, 2023 4:56:25 PM(UTC)
Guest
Rank: Guest
Groups:
United States
THANKS FOR?YOUR TIME AND CARINGNESS TO HELP?OTHER WITH THIS CHALLENGE💯🙏👍
Guest
#10 Posted : Monday, July 17, 2023 6:17:05 PM(UTC)
Guest
Rank: Guest
Groups:
United States
In addition to the above trick (thank you) I also had to hit start time button.
So it was hold oven light button, off and stat time all at the same time.
2 Pages12>
