katlatigo
#1 Posted : Monday, January 19, 2009 12:57:09 PM(UTC)
katlatigo
My GE microwave started sparking behind the waveguide cover. The cover was scorched. When I removed the cover, I noticed the part behind it had a scorched appearance. I replaced the waveguide cover and the microwave worked fine for a couple of days, now it is sparking from the same place again. Is the part behind the waveguide cover part of the magnetron?
magician59
#2 Posted : Tuesday, January 20, 2009 8:27:36 AM(UTC)
magician59
Yes. Check first for signs of loose connection on the leads to the magnetron. [COLOR="Red"]STEP ONE: ALWAYS UNPLUG MACHINE AND SHORT THE CAPACITOR BEFORE PUTTING HANDS INTO THE CABINET.[/COLOR] If you don't see anything obvious, you may need to replace the magnetron. This is trickier than it looks. You must do a microwave leak test whenever you remove and replace a magnetron. Excessive microwave leakage inside the cabinet can wreck havoc on the electronic controls. Also, a bad magnetron is very often a symptom of another component failure.
