Hello, My refrigerator diffuser got stuck last night, I manually opened it and everthing was fine and cooling in the refrigerator. Today I noticed some condensation on the milk container, also there are water droplets around the defuser, how can I tell if it is working right, do I need wait and see if everything gets warm again. The refrigerator defrosted itself last night as I heard the water hitting the pan. Does the inside of the refrigerator normally defrost where condesation builds up on things and then gets colder to where there is no condensation. No sure if the problem is fixed or if it is something that controls the diffuser or if it is the diffuser itself. Thanks there was no real ice build up in the freezer just some frost on the coils when I checked last night but it also defrosted itself
Originally Posted by: JeffSch  ...My refrigerator diffuser got stuck last night...
...do I need wait and see if everything gets warm again... You don't have to wait and risk to loose your food. The problems with air diffusers is one of the most common problems with Whirlpool refrigerators. So just replace it. - The air diffuser Part number: AP3046080
