billdiamond
#1 Posted : 14 years ago
billdiamond
Two issues that I have are:
1) The dispenser flapper stays open after ice is dispensed. How and where can this be lubricated and how do you remove the bezel on the door?
2) The ice dispensed is always in cube form regardless of the crushed - cubed switch
Joe / APP Team
#2 Posted : 14 years ago
Joe / APP Team
Bill,
Here is some basic teardown instructions for your refrigerator dispenser assembly. Once your inside, you should be able to determine what's broken or jammed or damaged.
If unit has Ice ‘n’ WaterTM door:
a. Apply masking tape to the blade of a putty knife or screwdriver. Use your masked tool to remove plastic Crush/Cube selector button from dispenser
escutcheon.
b. Use masked screwdriver or putty knife to pry bottom edge of escutcheon up, away from door. Be careful not to mar door finish.
c. Pull remaining three sides of escutcheon up, away from door, and set escutcheon aside.
3. Remove two screws that anchor electrical bracket cover. Separate cover and bracket to access ice, water and cavity-light switches.
4. Remove two screws and clips that anchor water actuator arm and return spring.
5. If you want to replace the water tube, remove watertube retainer clip. Pull water tube out of door and thread new tube through.
6. Remove four screws and clips from ice door. Remove ice door delay-retainer screw and retainer. Remove ice door and delay mechanism.
Good Luck,
