Our dishwasher seems to run forever. Even when we use "quick wash" it will run for an hour and a half. The other cycles run extremely long, too. Everything else about it operates well, it just runs on and on and on.
Whats the incoming water temp?? (DON'T GUESS) If its under 120 degrees, Turn it up!!!! If its over 120, Replace the timer.
