glenn.martz
#1 Posted : Monday, October 29, 2007 7:22:51 AM(UTC)
glenn.martz
After replacing the clock, the keypad does not work except for timed bake and timer 1. None of the other keys do anything. The oven light stays on and the cooling fan stays on, with or without the new or old clock installed. When checking the new clock out, I accidently grounded one of the hot terminals on the upper left top burner control (it works fine after resetting the breaker).
Did I damage the relay board?
#2 Posted : Monday, October 29, 2007 3:15:54 PM(UTC)
Does it show any error code after the new clock has been installed and everything connected?
glenn.martz
#3 Posted : Monday, October 29, 2007 6:16:55 PM(UTC)
glenn.martz
There are no error codes ever.
