Have Kenmoe drop-in stove Model # 62945766790. Was working correctly yesterday than ran self clean last night and now oven wont heat up over 190 Degrees (at least thats what the display says). Element gets warm but does not turn red and dont see any damage (cracks in it). Burners up top seem to work correctly? what should I check.
Does the Broil work?
Pull the Bake heating element out and check for burned wires. Remove the wires from the heating element and check the heating element for continuity. Check for 120VAC between the each wire and ground. Check for 240VAC between the wires. Post the results.
