I used the self cleaning feature yesterdy, and when I went to use the over the next day, it wouldn't heat up. Did I burn it up?:confused:
A Model Number may help.
Many stoves have an overheat thermostat perhaps it tripped during your self clean and did not reset. Often attached to the back wall of the oven (outside) |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  A Model Number may help.
Many stoves have an overheat thermostat perhaps it tripped during your self clean and did not reset. Often attached to the back wall of the oven (outside) I have same problem, model Rbd275pdq
