My 2 year old unit is displaying the incorrect room temperature on the digital display screen while on fan mode. This is causing the compressor not to come on. The temperature reading is typically 30 degrees off. I placed the thermistor under a cigarette lighter and the compressor kicks on. Which part do I need? Thanks for you assistance!!! :D
Originally Posted by: Chris311L  My 2 year old unit is displaying the incorrect room temperature on the digital display screen while on fan mode. This is causing the compressor not to come on. The temperature reading is typically 30 degrees off. I placed the thermistor under a cigarette lighter and the compressor kicks on. Which part do I need? Thanks for you assistance!!! :D Unfortunately the PC board needs replacing. :mad:
