Nino Hero
#1 Posted : Sunday, January 18, 2009 11:07:30 AM(UTC)
Nino Hero
8 Month Old, Has worked Flawlessly. Now, Does not fully Drain and leave diry water in the bottom. I took off the exhaust hose and stuck it in a bucket to rule out disposal/sink drain. Same problem. The exhaust hose is still secured securley High to the top of the sinnk. Any Suggestions would be appreciated.
#2 Posted : Monday, January 19, 2009 3:40:18 AM(UTC)
Check the sump for debris.
If OK then I would put in a service call.
Why should you mess with it when it is covered under warranty.
