pcjamison
#1 Posted : Sunday, January 18, 2009 8:37:53 AM(UTC)
pcjamison
Main (8") radiant element remains hot /provides alot of afterheat once turned down. I just replaced the element- same problem. Is there some other thermostat or heat sensor I should be investigating? Thinking about moving onto the Infinite switch? Eventually the element fully cools down.
kayakcrzy
#2 Posted : Monday, January 19, 2009 4:30:04 AM(UTC)
kayakcrzy
I would replace the infinite switch, It is what regulates the temperature of the burner. Tom
