The dishwasher wouldn't drain out, just filled up and ran thru cycle as normal. Took bottom section out (where drain is at ), and found two pieces of plastic sitting by a steel shaft about 3/16 dia. w/ a flat on one side. Glued the pieces together , and was able to locate this part. Can anyone tell me how to put it in? I cannot find any information on how to install ...even the parts store couldn't tell me .It drains if you lift the spring next to the shaft, and fills up as normal.:confused:
THIS FORUM IS DEAD!!!!!!! |
The part is located (in find part catagory) maytag,model pdb2430awe, pump and motor, part number 23 (lifter).
Check out page 3-20 in the manual I attached in my earlier post. |
