Ice Maker And Water Were Never Hooked Up,when I Hooked Up The Water The Ice Maker Leaks . Is It The Water Valve Or ? Or Is There A Water Level Sensor ,float,or Some Kind Of Timer Or Controler That Activates The Water Valve? It Is Not A Small Leak
Originally Posted by: davel85  Ice Maker And Water Were Never Hooked Up,when I Hooked Up The Water The Ice Maker Leaks . Is It The Water Valve Or ? Or Is There A Water Level Sensor ,float,or Some Kind Of Timer Or Controler That Activates The Water Valve? It Is Not A Small Leak Did you ever get a reply or an answer? My Amana Refrigerator has recently began overflowing the ice tray of the ice maker. I have been told there may not be an actual overflow float valve, but may need a whole new ice maker. What, if anything, have you found out? Thank you for any help you can offer.
