shughes1
#1 Posted : Sunday, April 24, 2011 6:03:10 PM(UTC)
shughes1
I have a Maytag Neptune front loading dryer. There was a power outage last night and the power to the dryer did not restore. Is there a reset button for this dryer. i can not locate my manual.
#2 Posted : Monday, April 25, 2011 2:12:11 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for MAYTAG MDE5500AYW DRYER- ELE | AppliancePartsPros.com
There is no reset button.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
