dfirsdon
#1 Posted : Saturday, January 17, 2009 7:55:44 AM(UTC)
dfirsdon
Unplug the refrigerator, remove the wire from the "defrost" terminal on the control board and measure the resistance between this wire and the neutral orange wire (pin 9 on the J7 connector). The freezer must be cold at this time.
If the reading is about 22 Ohms then the main control board has to be replaced. It is recommended to replace the board together with both freezer thermistors.
i have a ge model #gbs22kbpabb that the defost system is not working. i tested the conector as stated above and got 15 ohms. i have tested the heater itself and got 31 ohms. also tested the thermistor cold and at room temp. and have continuity both ways. not sure where to go from here. any help would greatly be appriaciated.
thanks
dave
libertyappl
#2 Posted : Saturday, January 17, 2009 8:19:06 AM(UTC)
libertyappl
It would seem that the control board is the part to be replaced. Part # Part Details - GE BOARD ASM MAIN DOMESTIC, part number: WR55X10656
Nat
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
GE Refrigerator DFE29JSDASS (Dishwasher Repair)
by DOUGZARA 4/24/2024 9:43:25 AM(UTC)
GE Refrigerator “dead” (Refrigerator & Freezer Repair)
by Guest 12/3/2023 8:03:32 AM(UTC)
GE refrigerator inside light not working (Refrigerator & Freezer Repair)
by Guest 11/18/2023 10:01:46 AM(UTC)
GE Refrigerator model# TFF24RBC (Refrigerator & Freezer Repair)
by Kenny67 11/3/2023 8:29:39 PM(UTC)
Dim interior LEDs in GE Refrigerator - update (Refrigerator & Freezer Repair)
by Craigma 11/3/2023 12:37:37 PM(UTC)
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 7/2/2023 1:59:53 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
GE Refrigerator parts (Refrigerator & Freezer Repair)
by Guest 6/5/2023 7:31:51 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
GE Refrigerator Model PSS26LSRF SS (Refrigerator & Freezer Repair)
by Phoenician 8/14/2022 10:03:28 AM(UTC)
GE Refrigerator Model GSS23WSTASS (Refrigerator & Freezer Repair)
by lkrier0612 7/18/2022 6:18:04 PM(UTC)
GE Refrigerator PWE23kskkss (Refrigerator & Freezer Repair)
by bubba1531 4/14/2022 6:47:57 AM(UTC)
