nagrath
#1 Posted : Friday, April 22, 2011 12:59:53 PM(UTC)
nagrath
Trying again, since no one has answered my previous posts: My GE GSD4030Y70WW dishwasher has suddenly begun stalling mid-wash. If I do not advane the timer myself, it will run forever, it seems. I have done the following: Replaced the timer: no change. Tested the water temperature: 135-140 degrees. Checked all wiring harnesses and fittings. Still does the same thing. Where is the sensor/thermocouple/thermostat in this dishwasher that would send a low temp signal to the timer to tell it to stop? I don't see it in the parts diagrams. What should I replace next? Help!
John
#2 Posted : Saturday, April 23, 2011 8:28:43 AM(UTC)
Replacement parts for General Electric GSD4030Y70WW Dishwasher | AppliancePartsPros.com
This is an old unit and I do not believe it has any type of temperature feedback. It does not even have a hi-limit thermostat.
Here is a manual for older GE,s though it does not actually list your unit.
31-3280 Clean Design Electro-Mechanical GE Dishwasher Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I only include so you can check if your unit has a cycle extender switch.
If not then odds are that there is a problem in the push button switch assembly as it does not sound like you have anything mechanical jamming the timer.
GE likes to keep everything technical a secret so the above is the best I can do.
Ge Dishwasher Problem (Dishwasher Repair)
by southerngent 10/26/2010 7:49:48 AM(UTC)
GE dishwasher problem (Dishwasher Repair)
by fishon10 8/13/2010 6:47:11 AM(UTC)
