red574
#1 Posted : Friday, January 16, 2009 3:58:05 PM(UTC)
red574
Is there a schematic for replacing the drum rollers and belts on a Maytag Neptune dryer Model # MDG3000AWW?
RED
#2 Posted : Friday, January 16, 2009 5:04:26 PM(UTC)
Here is the parts breakdown
Model MDG3000AWW
And this will tell you how
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
kayakcrzy
#3 Posted : Saturday, January 17, 2009 5:01:54 AM(UTC)
kayakcrzy
I don't think the breakdown will tell you all you need to know. First unplug the dryer, and what we need to do is get the front off. So, open the door, and there will be a phillip head screw that holds the upper door hinge in place. Take it out, and the lower one, and then grab the door, and lift it up, and pull it out. Set the door down, and on the other side you will see the 2 phillips head screws in the same place, take them out, and then pull the front off. Now right infront of you, where the filter is, there will be two long screws, take them out. I believe they are a 1/4 inch screw head. Now we have to lift up the top of the dryer. Just below the top, on the left, there is a metal bracket, with a 5/16s screw, take it out, and do the same on the other side. Then lift the top up, and rest it on the back wall. Now we need to take the blower assembly off, and the front cover, that holds the door switch on it. There will be a few 5/16 screws holding it on, and remove it, and then there will be a few screws holding the blower assembly on, they all are 5/16th screw heads. Remove it. Now all we have to do is reach in and push the idler are to the side to loosen the belt tention, and then remove the belt, and the drum, and you are there. You will need a pair of snap ring plyers. Good Luck. Tom www.applianceeducator.com/parts
