door is stuck in lock condition...f22 fault on display;;;;;is there anyway to open without breaking open thanks
Originally Posted by: drdavid  door is stuck in lock condition...f22 fault on display;;;;;is there anyway to open without breaking open thanks Dave , there are two methods of manually unlocking the loading door latch assembly. We're sending both, just in case. :) :) :) Good Luck, #1 Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened. #2 Manually Unlocking the Door Lock System 1. Unplug washer or disconnect power. 2. Remove the top washer panel. 3. Reach down along the inside of the front (between tub and CCU) and locate the top of the door switch/lock assembly. 4. Located on the top of the door switch/lock assembly is a ring-shaped tab. 5. Gently pull the tab upward about ¼" or until a click is heard. 6. The door may be opened.
