marv
#1 Posted : Saturday, October 27, 2007 1:49:15 PM(UTC)
marv
i fix the heat and it only last 1 or 2 days ?????????????:mad:i have changed the thermal cut-off and the thermal fuse the cut off gose out in 1 or 2 days what do i do
fixxit
#2 Posted : Saturday, October 27, 2007 2:00:31 PM(UTC)
fixxit
when you replace the thermal cutout you should also change out the operating thermostat as it is probably why the cut out went. good luck and post your results here
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
