I have had problems in the past with this washer. When you close the door and try to start the washer you get an error message that says dr for door. I have had the door lock assy repaired once before I'm trying to verify that its the same problem that's happening again. Please help. I so I can purchase the part to save money.
There are some tech notes inside the lower service panel which will show you how to put it into a diagnostic mode and how to test some of the components. Focus on the wiring between the door lock assembly and the CCU and the door lock assembly itself.
I realize you had it replaced, but it is a weak spot on these units, so see what you can find out.
