I have a Kenmore Dryer that is not getting power to the motor or heat element. There is power going to the timer and on/off switch. Please help!
Your Mod.# dosent come up, Does your dryer have the lint filter in the top of the dryer?
yes the filter is in the top
OK, Remove the rear panel of the dryer, UNPLUG IT FIRST!!! Look down just above and slightly to the left of the 4" outlet, There should be a little white fuse with 2 light blue wires going to it. Unplug the 2 wires and connect them together and tape them up so that there is no exposed wire or terminals. Plug the dryer in and try it. If it works, replace the little white fuse. DO NOT LEAVE THE DRYER THIS WAY!!!!!! THIS IS JUST FOR TESTING!!!!!! REPLACE THE FUSE!!! DONT RUN THE DRYER TO DRY CLOSE UNTIL YOU REPLACE THE FUSE!!!!:)
