alaucks
#1 Posted : 16 years ago
alaucks
Serial #XL3506189, oven displays error code E6F2. After awhile oven will beep and I can set the clock and the oven will work for a little while then the error code comes up again. Sometimes oven works for days and sometimes is off for days. After contacting Whirlpool directly they told me I needed a new touch pad, P/N 8300437. Before we replaced the part a local service tech told us to pull the oven out to make sure there wasn't a loose neutral. Now since we pulled the oven out, the oven does nothing, it doesn't even display the error code anymore. We received the new touch pad and installed and the oven still doesn't work. We were now told that we need to replace the motherboard or micro computer which I'm guessing is the clock or controlboard P/N 8302967. Before ordering it I wanted to get a second opinion.
Thanks,
Andrea
libertyappl
#2 Posted : 16 years ago
libertyappl
I would check the terminal block, where the cord attaches to the back of the unit first, that sounds like a short.
Nat
#3 Posted : 16 years ago
Just to add my 2 cents...
Check the power outlet too or just try a different one.
