I am pretty sure the door on the soap dispenser is not opening because the "controller" is not telling it to open or there is some other physical problem with the dispenser assembly.
I cleaned the dispenser thoroughly and tried new soap but the door still does not open. I tried another wash setting and that did not help either. The soap in the dispenser stays powdery so the soap is not becoming hard and causing the problem. The door clicks shut easily and opens easily when manually flicked open.
I would like to know if someone can provide step by step instructions for replacing the dispenser and or controller if you agree that is probably the issue. I would also like to know if the controller is inside the dispenser or is that a separate component?
I would like to repair it myself if possible. I can turn a screw and use a soldering iron.
I have some updated information.
The model number is: KUDP02CRBS2
Since my original post I have also tried running the dishwasher without any soap in the dispenser and I have tried increasing the temperature on my water heater. The original problem persists where the soap dispenser won't open.
Any suggestions?
