gregnese
#1 Posted : Thursday, April 14, 2011 9:16:21 AM(UTC)
gregnese
I already replace the solonoid valve thinking that was the problem and it wasn't. I also checked to see if the float was stuck and it is fine.
I did also have to replace the water line and checked the pressure and thats fine too.
Any thoughts on what to check next?
#2 Posted : Thursday, April 14, 2011 10:05:40 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for JENN-AIR DW861UQP DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
I am assuming that the unit is not totally dead and the only problem is no water.
You will need a meter.
Check across the water valve and the float switch combo for 120 volts when it should be filling.
If it is not betting voltage then either you have a bad wire from the timer to the combo or the timer is toast.
If there is 120 volts then check just across the float switch. If it has 120 volts across it then it is not closing and is probably toast.
gregnese
#3 Posted : Thursday, April 14, 2011 11:16:34 AM(UTC)
gregnese
Thanks for the reply. I will put a meter to it and see.
