deshawood
#1 Posted : Tuesday, January 13, 2009 4:12:35 PM(UTC)
deshawood
It has stopped heating on the "Convetion Bake" setting. All the other settings still work. What is the most likely cause? What part number do I need?
Joe
#2 Posted : Wednesday, January 14, 2009 10:42:48 AM(UTC)
Hi Joe,
Does the convection fan work when you set the "Convection Bake"?
deshawood
#3 Posted : Wednesday, January 14, 2009 3:50:18 PM(UTC)
deshawood
Gene,
Yes, the fan comes on and the "Heating" light comes on, but it never heats up.
Joe
#4 Posted : Wednesday, January 14, 2009 6:39:20 PM(UTC)
Remove and check the convection heating element.
deshawood
#5 Posted : Thursday, January 15, 2009 3:06:55 PM(UTC)
deshawood
Gene,
I was assuming there was only one heating element for both Bake and Convection Bake. You are saying there is a separate Convection heating element?
Is it behind the convection fan?
If so, I assume if I slide the oven out of the cabinet and remove the top or back panels I can access the heating element?
And then just check for conductivity?
Thanks, Joe
#6 Posted : Thursday, January 15, 2009 7:27:17 PM(UTC)
Joe,
The convection heating element (#298 on the break down diagram) is behind the rear panel (#248) inside the oven. Remove it and check for continuity.
- The part number for the convection heating element is AP2031064
deshawood
#7 Posted : Saturday, January 17, 2009 5:10:06 AM(UTC)
deshawood
Thanks Gene,
You nailed it. The heating element was fried. I can see exactly where it failed, there are small bubbles on the surface of the element in the area of the failure. Also it is dead when I check it for continuity. I have ordered the replacement element.
Thank you for your excellent help!!!
Joe
#8 Posted : Saturday, January 17, 2009 3:32:53 PM(UTC)
