The light "Energy Saver Dry" does not lit when pressed. All the other lights light when the key is pressed. And the dishwasher will not start when I press start. If I hold the key "Energy Saver Dry" for more than 4 sec the child lock does NOT lid. Anybody have seen this problem before and knows what it could be. I tried to change the electronic panel but the same problem happen. Could it be the touch-pad? How to check if its is ok? Any advise is welcome. Thanks
Marco,
Does any light on the control flash?
No, no lights are flashing. All the other key seems to work well with the exception of "Energy Saver" and "Start". And of course "Cancel" becasue I assume there is nothing to cancel.
I'm suspecting the key-pad. Thanks for any advise.
Looks like you are right. If you need the correct part number for the key pad then post the color of it.
