sbfire370
#1 Posted : Wednesday, April 13, 2011 3:24:11 AM(UTC)
sbfire370
My electric duet dryer runs but no heat. What could be the most likely issue?
#2 Posted : Wednesday, April 13, 2011 5:25:08 AM(UTC)
Replacement parts for WHIRLPOOL GEW9250PT1 ELECTRIC DRYER | AppliancePartsPros.com
Here is a manual, although for an older unit it should be close to yours.
L-69 Whirlpool Duet Gas & Electric Dryers Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
First I would check the power to the unit.
The control board, motor use 120 but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If power is OK I would unplug the unit and check the heating coil, the thermal cut-off and the hi-limit thermostats for resistance.
If the thermal cut-off is blow (open) then there are other things you should check before replacing it.
File Attachment(s):
GEW9250.pdf (357kb) downloaded 285 time(s).
sbfire370
#3 Posted : Wednesday, April 13, 2011 10:59:25 AM(UTC)
sbfire370
Got it, heating element was broken
Originally Posted by: denman Go to Quoted Post
If OK
If OK
