TravisG
#1 Posted : Tuesday, April 12, 2011 1:30:52 PM(UTC)
TravisG
I have a General Electric dryer that is not running. The timer seems to be working fine, but when you push the start button all we get is a humming sound. Since I can hear a humming sound I assume the starter switch is fine and am leaning towards the motor.
I didn't have my meter with me, but will take it home with me tonight just thought I would check with the experts and see if there were any other suggestions. Thanks in advance.
#2 Posted : Tuesday, April 12, 2011 4:16:56 PM(UTC)
Originally Posted by: TravisG Go to Quoted Post
...Since I can hear a humming sound I assume the starter switch is fine and am leaning towards the motor...
Travis,
You are on the right track. There is a simple test for the motor. Open the door and tape in the door switch. Push the start button and at the same time turn the drum manually. If the motor will start, no doubt it is the culprit.
- The motor Part number: AP2043570
TravisG
#3 Posted : Friday, April 15, 2011 7:15:44 AM(UTC)
TravisG
Thank you Sir. Got the new motor and will install it in a bit.
Guest (4)
