I have a Maytag Quiet Series 200. When I first turn it on, I have water leaking from the left side. Pulled out dishwasher and found awhite plastic assembley on the left side where black rubber water supply hose connects to. the water is leaking for a short time from a rubber gasket connecting this white plastic piece to the side of the dishwasher frame. How do I remove this unit to replace/repair?
Is it worth repairing or should I replace?
Groups ready for retrieval: Senior Expert
just remove the hose from the top and run a rat tail file down it it has hard water build up causing the back spray and leak
