aholcombe
#1 Posted : Thursday, April 7, 2011 1:57:57 PM(UTC)
aholcombe
I had an error 41 code and replaced the locking unit for the door. I then went through and did the 9 step diagnostic test....everything was fine. Now 30 minutes later the unit is beeping again and the lights are flashing. I did an error check and it is saying e00. I ran an empty cycle and the washer works fine.
I need help.
sidfink43
#2 Posted : Friday, April 8, 2011 4:10:38 PM(UTC)
sidfink43
If you post a model number someone may be able to assist.
