Microwave lost all power while in use. It was like it blew a fuse. I've checked the breaker and replaced the 250v 20 amp fuse. But still nothing. I had to replace the fuse 3 or 4 years ago when the same type of thing happened. But this time that didn't work. It's over the oven type with a hood.
Any ideas?
Thank you, Varon
ck to see if you are geting 120v at you control if you are and still no display you may need Part Number: AP3118396 , the 120 going in to the control is going to be on one of the black switchs on the control with 2 wires going to it i could not find the wire lay out
I'll give that a try. Varon
