GE PDW9700J00II There are two prongs on the back of the soap dispenser. There are two connectors that attach to them, one has two white wires, the other has one red wire with a yellow stripe. Does anyone know wich connector goes on wich prong. (One is closer to the front, the other closer to the back.) If not does anyone know where to find a wiring diagram. Thanks for the help!
THIS FORUM IS DEAD!!!!!!! |
Thats a great site. I found a picture of the module and the wiring. Thanks very much for your help
