we moved this home last october and has a ge profile over the range microwave oven it works fine but the light under the oven does not work the light can be turned on and off in three different level from touch control panel Changed the both bulbs which has two prong 120 volts bulbs still does not work somebody repaired this microwave oven and removed the model # from inside this oven is about 30 inch wide and it looks fairly new it is stainless steel please help how to remove the touch control panel which is on the right hand side of oven and about 6 inch from handle
Unfortunately without complete model number it is impossible to find any technical information and/or replacement parts.
