srooney123
#1 Posted : Wednesday, April 6, 2011 10:02:05 AM(UTC)
srooney123
Our dishwasher is making a loud humming sound as it cycles. I think the motor bearing is out of it but I can't get the impeller off the motor shaft. How do you remove the impeller? With a puller or does it unscrew?? Thanks
Joe / APP Team
#2 Posted : Thursday, April 7, 2011 6:26:49 AM(UTC)
Joe / APP Team
Srooney,
The impeller assembly, screws on and off the motor shaft, it is a standard thread configuration, clockwise to tighten, counterclockwise to loosen.
You'll need to carefully insert a screwdriver into the cooling vents on the back of the motor, to hold the armature and shaft still, while turning the impeller counterclockwise (it's a pretty long threaded shaft, and once you have the impeller loose you can remove the screwdriver).
Good Luck,
