jbhew
#1 Posted : Wednesday, April 6, 2011 9:27:21 AM(UTC)
jbhew
Washing machine fills for wash cycle. It agitates and then drains after wash cycle. Will not refill for the rinse cycle. Then won't go into spin cycle. I can hear the timer running but doesn't seem to advance into the rinse or spin cycle. Have replaced the lid switch assembly and the pressure switch/tube. Still no results. What is going on here???????
sidfink43
#2 Posted : Thursday, April 7, 2011 5:09:29 PM(UTC)
sidfink43
I am not sure exactly when the problem occurs. If it will go through the wash cycle including spin, then it is likely a timer or control problem.
I cannot get your model number to come up, so that is about the best I can do.
