didier
#1 Posted : Wednesday, October 24, 2007 2:01:14 PM(UTC)
didier
I am trying to repair this electric dryer with no heat,I have checked the power supply (240v) , the heating element, thermostat, over heat fuse link, centrifical switch at the motor, and I can't find the problem.I did replace the timer assemble with no new results.The motor will run and the blower is operational as well. I can't seem to figuire this one out, I hooked up the heating element assembly with its safetys direct to 240v and it operates.The model is a Amana electric cloths dryer #LE3502L, S/n 9206006443.I am open to any input. Thank You
jdappl07
#2 Posted : Friday, October 26, 2007 6:25:11 PM(UTC)
jdappl07
check for any vurnt wires from the terminal block to the heater
