tami
#1 Posted : Friday, January 9, 2009 3:58:28 PM(UTC)
tami
My washer has developed a leak that happens when the washer is draining. Where do I begin to find the problem. All drain hoses and water supply lines are sound.
misterfixall
#2 Posted : Friday, January 9, 2009 5:02:06 PM(UTC)
misterfixall
the leak may be at pump, which is at front middle, tip machine back after draining out and feel all around pump ,it is white with 2 hoses attached
