gantone1@yahoo.com
#1 Posted : Tuesday, April 5, 2011 3:03:08 PM(UTC)
gantone1@yahoo.com
Our water softener displays L11 and F40 when you first power it up, then clears the error codes and flashes the time and beeps. It does not cycle. I cannot find any information about these error codes.
Please Help if you can!
Thanks!
rjh2o
#2 Posted : Friday, May 13, 2011 7:01:33 PM(UTC)
rjh2o
If the unit does not clear the code after unplugging for 2 minutes and plugging back in. The drive motor is most likely bad and needs to be replaced.
RJ
