I have a LG Tromm DLE2512W electric clothes dryer that is making a thumping noise in the front just below the door. I have taken the dryer apart and have found nothing loose or wobbling. The part that I think was making the noise is related to the lint blower housing that is located in this area because I felt the front while it was running and was able to push the front panel into something that softened the noise. What advise do you have?.
Originally Posted by: mbilthuis  I have a LG Tromm DLE2512W electric clothes dryer that is making a thumping noise in the front just below the door. I have taken the dryer apart and have found nothing loose or wobbling. The part that I think was making the noise is related to the lint blower housing that is located in this area because I felt the front while it was running and was able to push the front panel into something that softened the noise. What advise do you have?. did you find solution to lg tromm dryer thumping
How do i remove front mount control panel
