dmd5
#1 Posted : Thursday, January 8, 2009 4:26:01 PM(UTC)
dmd5
Washer cleans well, but the timer will go to 1-min and just sit there
washing forever. Water doesnt seem very warm when I open the door.
It does it in every wash mode, even quick wash. It may have nothing to do
with heating the water as I dont thing quick wash heats the water.
I am sure that this has been seen before, just cant find it or the model.
I tried looking up the model on the door SHE56C05UC/36 and
any combination and cant seem to find anything close.
I can use the 2 buttons and reset it so it will drain, then use the
rinse and hold to flush it out
Thx in advance..
DB4156
#2 Posted : Sunday, January 11, 2009 5:54:11 PM(UTC)
DB4156
i don't know if this will help, but my old Bosch dishwasher did the same thing. Problem was a faulty circuit board (soldering joints). Bosch knew of the problem (defect). Replaced the circuit board. Problem went away. Then after awhile, did the same thing. They replaced the circuit board again - never had another problem after that.
dmd5
#3 Posted : Sunday, January 11, 2009 6:54:01 PM(UTC)
dmd5
Thx - that is what I found too with further investigation.
Mine is still under warranty so I have scheduled
a call. Part is free, just the service costs.. So I will have to pay something.
For now we just run it for awhile and the use the reset to drain. Then run a
rinse and hold. Works for now until it can get fixed.
jceaser_11
#4 Posted : Sunday, January 25, 2009 3:24:58 PM(UTC)
jceaser_11
is that what it was becaues a have one doing to same and a put a new ccu in and did the same , but the ccu could have been bad
dmd5
#5 Posted : Sunday, January 25, 2009 3:30:40 PM(UTC)
dmd5
Had the new main module replaced and all is well. When the guy
pulled the old one out, I opened the plastic case it was in. There
was a burnt spot on the board just like in other posts.
My washer has a 5-yr warranty for circuit boards and such, so it was just\labor of $100. That was just a few $$ more than just the board and shipping.
