AppliancePartsPros.com
Appliance Repair Help
Washer Repair
rattles inside washer when it agitates and spins
The inside of the washer rattles when it agitates and spins. It sounds like there is some inside moving around. It still fills and drains.Any ideas what it might be. ?
Take off the front cover by inserting a screw driver carefully in the gap between the top and front near the edge to release clips that hold the front panel to the cabinet.
Check to see if anything is caught between the tub and basket, and then run it to see if you can hear the location of the noise.
Washer Repair
