David Maheu
#1 Posted : Tuesday, October 23, 2007 11:33:20 AM(UTC)
David Maheu
There is a water leak comming down the stand pipe of the float switch assembly. I ordered a float switch assembly and do not think that will solve the problem, since the float looks different on line and there is a space when the shaft of the float goes into the switch assembly. Is there suppose to be a gasket inside the float to prevent water going down the assembly shaft.
#2 Posted : Wednesday, October 24, 2007 1:10:06 AM(UTC)
Pull front bottom panel and remove the float retaining clip and remove float. Check the tub, you will probably find a crack in the tub. Sand it and clean it and put some silicone cement on it.
