mageegd
#1 Posted : Tuesday, January 6, 2009 3:51:33 PM(UTC)
mageegd
My door will not close. It is as if it is hitting something inside the unit. If I pull up on the door, it will close.
Nothing is different, it just started happening. Does it need adjustment?
Any ideas?:confused:
#2 Posted : Wednesday, January 7, 2009 7:01:54 AM(UTC)
Your Model Number does to seem to be complete.
Look at the bottom hinge often they have a plastic cam assembly.
Door rides up slightly when closing then down a bit when closed, helps keep the door closed.
Yours may be broken.
