My washer will not fill with water. I did a load yesterday and two loads of laundry this morning and when I went to do the third and the machine went right to wash mode.
there is a pressure switch in the controls which choses the size of the load and amount of water. Take the clear hose going down the side of the tank off and blow in it if you hear a clicking noise there is something in the dome on the side if the tank if not you need a pressure switch
