Martha Shelby
#1 Posted : 17 years ago
Martha Shelby
The washer will was but will not go into the rinse or spin cycle. You can hear a small humming noise....any suggestions of what might be wrong?
jdappl07
#2 Posted : 17 years ago
jdappl07
pull the pump off the front of the motor and jump the lid switch with a wire between the two wires ([COLOR="Red"]not the green one[/COLOR])start it in spin. If it goes replace pump if not pull motor off maybe broken motor coupler if not it is the clutch assy
#3 Posted : 17 years ago
If the washer agitates ok, but no spin, it's probably a bad timer.If no agitate, probably a bad coupler.
Roper washer will not spin or drain (Washer Repair)
by Jfriedm 15 years ago
Washer will not spin or drain (Washer Repair)
by templejazz82 16 years ago
washer will not spin or drain - leaks (Washer Repair)
by BARCHER 16 years ago
by Martha Shelby 17 years ago
