jmpjr99
#1 Posted : Tuesday, January 6, 2009 5:31:13 AM(UTC)
jmpjr99
This first happened three weeks ago. Freezer cold (20 degress)but not cold enough and refrig was warm (48 degreees). Freezer back panel had a heavy frost coating. So I unplugged and used a hair dryer to defrost. Everything worked fine until last night. Same issue as before
So this time I manually turned the defrost time as instructed, waited 10-15 minutes and listed for a sizzling sound..nothing. I then removed the back panel and it was almost solid ice. I do not have a have a working ohmmeter so I can't test for continuity.
So does this mean it's the defrost heater or the defrost thermostat. I am tempted to replace all 3 parts.
Any suggestions.
James
#2 Posted : Tuesday, January 6, 2009 6:22:59 AM(UTC)
Here is your parts breakdown
Model GB22DKXGW00
You could replace all three. Looks like your total bill would be about $80.00.
Unless of coarse if it is an uncommon problem like a bad connection in which case you have wasted $80.00. Personally I would buy a meter, see below.
Here is a diagnostic which may save some dollars
Mark the timer shaft/cam and the body with a line using a felt tipped pen.
Let the unit run for a couple hours
if your lines are still lined up it tell you that the timer is not advancing and needs replacing.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
