My dishwasher has a flashing start/resume green light. Sometimes the dishwasher will work, sometimes it stops during a cycle, then the light flashes. Sometimes it will not work at all, as is the case at the moment.
All the buttons on the control panel work. I've tried resetting the board and power cycling the machine.
The light flashes continuously until the cancel button is pressed. I've also noticed a small "click" sound just before the flashing starts, it seems to be coming from the control panel.
Any thoughts? Also do you know what size torx wrench is needed to access the panel / ribbon cable?
thank you
Had the same thing. Flashing start button. Turned off the power. Took off the inside panel on the door. Removed the touchpad ribbon cable from the control board. The problem was the broken traces on the ribbon cable. So I went to the automotive store and asked for the kit that repairs the rear defroster grid. It has a paint in there that is conductive. I saw where the traces where broken so I used a really sharp exacto blade (you should consider sand paper) to remove the covering so that it exposes the metal trace. Than I painted the line with a toothpick to make sure it connected the trace. Covered most of the area with plastic and tape so it is not exposed. Turned on the power. Brilliant!!!!!!!!!! It worked like a charm and I saved myself $150.
