ronbo
#1 Posted : Monday, January 5, 2009 8:34:59 AM(UTC)
ronbo
Frigidaire Plhs267zab3 Food Freezes In Food Compartment With Thermostat On Lowest Setting.
#2 Posted : Tuesday, January 6, 2009 2:16:19 PM(UTC)
Most likely the problem is a bad damper control which should regulate the cold air flow from the freezer. Unfortunately Frigidaire does not sell it separate and it comes as a part of the control assembly.
- The part number for the damper control assembly is AP3140255
